- Define the vendor option.
 - Create the vendor class.
Perform this procedure to configure vendor option data for a vendor class.
The switch follows inheritance and precedence rules for configured DHCP Server options.
The switch process the DHCP options in the following order of precedence:
- host—Host configuration applies only to a specific host.
 - DHCP subnet—DHCP subnet options apply to only those clients within the specified subnet.
 - vendor class—Vendor class options apply to only those clients with a string that matches a specified vendor class identifier (VCI).
 - global—Global options apply to all clients.
DHCP Server builds a cumulative configuration from all scopes but applies precedence rules in instances of conflict.
 - Select DHCP Server.
 - Select the Vendor Class Vendor Option tab.
 - Select Insert.
 - In ID, type the DHCP code that you defined for the vendor option.
 - In Vendor class id, type the value to apply to the vendor option.
 - In Value, type the value to assign to the vendor option.
 - Select Insert.
Vendor Class Vendor Option Field Descriptions
Use the data in the following table to use the Vendor Class Vendor Option tab.
| Name | Description |
| ID |
                                 Specifies the vendor class ID.  |
                                 Code  |
                                 Specifies the DHCP code that identifies the vendor option.  |
                                 Value  |
                                 Specifies a data value to apply to this vendor class.  |
